need help
not getting any sound from 1210s when source button pressed using traktor dj 3 and setings mixed up on hercules can any1 help thanks gang
hello dj funked,
1) what is your dj console version: is it dj console mk2 or dj console rmx?
- in case it is dj console mk2, was ist software pack virtualdj djc 3 or traktor 3 le?
2) what is the traktor 3 dj software you refer ?
is it traktor 3 le or traktor 3 dj studio ?
3) what is(are) the model(s) of the cell on your 1210s?
if you have a rmx try using it in wdm mode, you might get lucky :d
Hello DJ Funked,
1) What is your DJ Console version: is it DJ Console MK2 or DJ Console Rmx?
- In case it is DJ Console MK2, was ist software pack VirtualDJ DJC 3 or Traktor 3 LE?
2) What is the Traktor 3 DJ software you refer ?
Is it Traktor 3 LE or Traktor 3 DJ Studio ?
3) What is(are) the model(s) of the cell on your 1210s?
if you have a RMX try using it in WDM mode, you might get lucky πŸ˜€
