1
Posts
2
Users
Reactions
Views
28/03/2020 10:17 am
first of all, greatings for good people of the globe.
i need help with connecting my gear together.
here is my setup
31/03/2020 12:46 pm
The way you connect depends of what you want to do.
I would probably:
- connect the output of the Audio Technica turntable to the input 1-2 of DJConsole 4-Mx, connect the ground of the Audio technicato the ground screw of DJConsole 4-Mx, open DJConsole 4-Mx control panel and set Input 1-2 on Phono,
- connect the master output 1-2 of DJConsole 4-Mx to the Input 1-2 of Roland MX-1
- connect Roland MX-1 to the USB port of 1 computer, and connect the DJConsole USB to the USB port of another computer
- connect the speakers to the Output L-R Mix Out of the Roland MX-1
And I do not know what you wand to do with the Faderbox Micromodule, but you probably know why you want to use it.
