need help with herc...
need help with hercules impulse 300 - recognized but not working
hello community!
i have an hercules impulse 300, which i have been using with no problems in my windows 10 computer. everytime, i connect the hercules to the pc with the usb cable and everything worked.
when i open djuced, it usually says that i should update de software and also the drivers.
i did that. updated the software and installed the drivers for asio. and now, the hercules 300 is recognized by djuced ( it shows up as an option for audio output) but all the buttons doesnt work. how can i fix it?
please help this young dj girl to get back on track! πŸ™‚
Hello djdjdj,
Welcome to the forum.
1) Please complete your profile wiith the basic technical information in
In "Hercules equipment in use", please check the controller name
In "software in use", please check Djuced
in "Describe your equipment" field, please describe your computer
- Environment (for example Windows 10 64-bit Version 21H2 build 19044.1526)
- brand and model CPU RAM (as Lenovo Yoga Slim 7 Carbon 13ITL5 13,3" Core i5 16 GB RAM)
- Type of USB port (for example USB 3.0 Type A, USB-C, USB hub powered by a power adapter...)
- version of DJ software, as Djuced 5.3.7
- version of DJ driver (for example. 2022_HDJS_1)
- let us know if you have an exotic firewall or if you use Windows Defender (built in Windows).
2) If you have Google chrome browser installed in your PC, please
- connect the DJ controller to the PC,
- close Djuced if it is running
- go to  https://www.midimonitor.com/ (Morningstar Midi Monitor)
- check if it detects the actions on the DJ controller buttons and, if it detects the controls, check the MIDI channel when you press on Play on deck 1 and on Play on Deck 2.
3) Then in the forum, please precise in a new post:
- what you can read as firmware version in the about tab of the Hercules control panel
- and what you see in Morinigstar Midi Monitor with when you press on Play on Deck 1, and what you see when you press on Play on deck 2.
