need some help...
need some help...
i have a problem ..
i managed to make the hercules dj control mp3 to work on tracktor 3.2 after days of torment (it actually was easy but i didnt know what i was doing lol ). one of the controls i didnt managed to find and asign to the console is the wave display control.
i want to use the control mp3s jogs to scrool through the song just like a normal cdj, but i cant seem to find the command to asign it.
can anyone  help me ?
hello derfrosch,
you can take hercules tks file for dj control mp3 in traktor 3.
the file is for download in hercules technical support website
- http://ts.hercules.com
- go to updates and downloads
- in the download section, select "sound cards" as product genre, "dj controller" as product family, "dj control mp3" as product, "software" as link" and in "traktor dj - midi profiles", you can take traktor 3.4.1 preset.
even if traktor 3.4.1 preset can differ from a preset for traktor 3.2, it is very likely the jog wheel setting is the same in traktor 3.2 and in in traktor 3.4, so you can copy this part of the preset in the profile you write for your own traktor version.
Hello derfrosch,
You can take Hercules tks file for DJ Control MP3 in Traktor 3.
The file is for download in Hercules technical support website
- Go to Updates and Downloads
- In the download section, select "Sound cards" as product genre, "DJ Controller" as product family, "DJ Control MP3" as product, "software" as link" and in "Traktor DJ - Midi Profiles", you can take Traktor 3.4.1 preset.
Even if Traktor 3.4.1 preset can differ from a preset for Traktor 3.2, it is very likely the jog wheel setting is the same in Traktor 3.2 and in in Traktor 3.4, so you can copy this part of the preset in the profile you write for your own Traktor version.
