1
Posts
2
Users
Reactions
1
Views
02/01/2012 10:16 pm
ola alguien me sabria ayudar pk pongo los cascos i mienteas se escucha una cancio para poder escuhar la otra i esque no se me escuha nada por la entrada de audio de abajo es la djcontrolproair la tabla que tengo de hercules
gracias..
04/01/2012 12:35 am
To hear the preview in headphones on DJ Control Air you must:
1) push on the button Cue on DJ Control Air front panel: the Cue button is lit on, the Mix button is off
2) push down on the headphones select button (button with a headphone logo) on top of the volume fader of deck A or deck B
3) and play the track on the deck where you have activated the headphones select.
To hear the mix in headphones on DJ Control Air you must just push on the button Mix on DJ Control Air front panel.
