no sound coming out...
no sound coming out of output
i have been using the rmx2 for about 3 or 4 months now, i have an rca to aux cable plugged into my computer speakers to practice while im at home. if i have it plugged into channel 3-4 with the main channel as 1-2 and the headphones as 3-4 sound comes out of the opposite deck as the one my crossfade is on. but when i haveit plugged into 1-2 with the main channel on 1-2 nothing comes out of either deck. doesnt make sense to me. help please, i have a gig tomorrow.
A) Your message would be easier to understand if you could
1) Make a effort of writing a clearer title : for example "DJConsole Rmx2: no sound on booth output"
2) complete your profile: there is field "Hercules equipment in use", you can check the box "DJConsole Rmx2", and there is a field "Software in use", so you can click on the checkbox "VirtualDJ" .
B) In case you are in Windows (I suppose you use a computer in Windows since Mac users always precise their version of Mac OS), and in case your mix with VirtualDJ 7 LE Rmx2, then you can for example set the audio as follows:
In VirtualDJ > Sound Setup
- Inputs : none
- Outputs : headphones
   Master: Chan 1&2 / Headphones: Chan 3&4
- Sound Card: ASIO driver
  DJConsole Rmx2 ASIO
In Hercules DJConsole Rmx2 control panel:
Make sure the Booth, in the Output channel, is not set to zero or to Mute.
