20/11/2020 2:12 am
just got this controller, installed the djuced software, did all updates (firmware), cannot figure out why no sound coming from my home speaker, i do get sound in my headphones but nothing from sound system, plz help
20/11/2020 12:38 pm
You need to either connect your home speaker to your Inpulse 300 and check Djuced audio settings it's using Outputs 1&2 for master - or if those speakers are connected to your computer, check here if the Send MASTER to computer speakers option is ticked and you have selected the right output. Also make sure that the Master volume knob in the middle of your controller under the Hercules logo is set to the desired volume level
