no sound on pc
hello everyone this is my first post since i got my hercules rmx a week ago. i plug my rmx into my laptop and i get no sound..is that suppose to happen?
to be precise, you get no sound,
- when using vdj with speakers connected to the back of the rmx ?
- when trying to use your laptop speakers ?
the bundled version of vdj will only work with the rmx soundcard, so it is necessary to connect speakers to the rmx.
thats weird, when i had vdj pro with no rmx, i was able to use my laptop speakers...thanks phatso
indeed, the pro version can use any soundcard, but the rmx version was designed so you dont have to configure anything: simply connect the rmx to your computer, speakers and headphone to the rmx and you are good to go.
To be precise, you get no sound,
- when using VDJ with speakers connected to the back of the Rmx ?
- When trying to use your laptop speakers ?
The bundled version of VDJ will only work with the Rmx soundcard, so it is necessary to connect speakers to the Rmx.
Indeed, the Pro version can use any soundcard, but the Rmx version was designed so you don't have to configure anything: simply connect the Rmx to your computer, speakers and headphone to the Rmx and you are good to go.
