odd behaviour preve...
odd behaviour preventing use of hercules dj console
hi all,
hoping someone can give some advice as the following issue are stopping our 11 year old budding dj from practicing his mixing!!
bought a hercules dj console (original unit i think it is,jog dials,lots of inputs/outputs) same as this one
installed it onto a windows 8 laptop toshiba satellite pro and all was working fine.  then a few days in some odd behaviour.
when going to the music folder in windows explorer the music tracks would get question marks on them and refuse to play in media player.
then when opening virtual dj 8,wed load a track to the deck,press play and nothing happens, this is both on the controller and in the software.
then if we tried to close virtual dj it would warn us that music was playing even though the dials werent  spinning around and no sound was coming out.
not sure if this is something to do with the setting in the system tray icon config where you can select normal or dj mode.
 if we unplug the hercules usb controller then music will play normally in windows media player
if we plug the controller in and try and play the same track in windows media player it says
windows media player cannot play the file. the player might not support the file type or might not support the codec that was used to compress the file.
restarting the computer sometimes gets it going but not consistently so im struggling to figure out the cause.
any help or advice anyone can give would be greatly appreciated.
many thanks
noel
This seems indeed like a configuration problem which can be easily explained.
The short asnwer is that when you wish to use the DJ Console as a standard soundcard (for using Windows Media player and such), make sure the DJ control panel in the system tray is set to Normal, while when using DJ softwares, set it to DJ. This should keep you out of trouble with other similar applications as well.
The longer answer is that the DJ mode can be a source of headaches if you are not aware of a few details not obvious to beginners.
Virtual DJ, as it is the case for you, can operate in 2 audio modes:
- One, which is used by all normal programs such as Windows Media player, is called WDM;
- the other, designed specifically for music and DJ application, is called ASIO
Without getting too technical, what you need to know is that if VDJ is already using the DJ Console is ASIO, or the Console is simply configured in ASIO mode (box ticked in DJ mode), then no programs will be able to use it, giving you error messages such as the ones obtains with WMP.
By switching to Normal mode, you effectively disable the ASIO part of the driver.
<img src="data:image/png;base64,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
