16/12/2012 4:54 am
have a problem with my hercules dj console rmx.it continuosly ligths one deck and plays only half of the song.it also creates cue points,loops and forwards.have tried re installing the drivers bt still wont work
17/12/2012 5:26 pm
Can you be a little more detailled about your problem ?
Are you using a PC or a MAC, and with which operating system version ?
Which software are you using ?
Did you install the latest driver ?
Did the problem suddenly happen?
18/12/2012 2:51 pm
well,re installed new drivers and it works well aniway thnks man
