pitch and volume co...
pitch and volume control configuration possible?
hi! im just starting to learn how to mix using a hercules dj control mp3 that i got this christmas.
the thing is that several times i would like to use the slider in the dj control mp3 for pitch and in other songs for sudden changes in volume. there is an option for inverting pitch/volume control that its exactly what im looking for. the program included with the hercules control i think its the virtualdj home version. is there any way to change that option (a hotkey or something) in the middle of a mix?
it would also work for me if i could change the pitch wheel sensibility, as then i could change the volume very fast.
thanks!
technically, it would be possible for virtual dj to implement these options, but this is not currently the case.
virtual dj pro includes midi programming and hotkeys, which you can you to customize the way your controller and software behave, but not all the features you would mentionned have been implemented yet.
you might want to mention it on virtual djs forum, so they can possibily had it to their list of options to add in the future.
Technically, it would be possible for Virtual DJ to implement these options, but this is not currently the case.
Virtual DJ Pro includes MIDI programming and hotkeys, which you can you to customize the way your controller and software behave, but not all the features you would mentionned have been implemented yet.
You might want to mention it on Virtual DJ's forum, so they can possibily had it to their list of options to add in the future.
