pitch problems
pitch controls are somewhat insensitive they tend to jump around, for example when i am beatmixing and trying to match bpms it seems to jump around, if the playing song is 135, i can not always get the other one to match it tends to jump higher or lower. has anyone experienced this problem? any suggestions?
thanks
what version of vdj u using? is this on mk2 and are u using timescode?
i am using vdj 5.1 pro with hercules rmx. no timecodes
what is your pitch range set at? mine is on 33%
@spinnaj, fancy meet you here matesmile
i went to config - options in the vdj software (is that what you mean?) and changed it to -33 to +33
i will give that a shot.
thanks for the reply
What version of VDJ u using? Is this on mk2 and are u using timescode?
I am using VDJ 5.1 pro with hercules RMX. No timecodes
What is your Pitch range set at? mine is on 33%
@spinnaJ, fancy meet you here mateSmile
I went to config - options in the VDJ software (is that what you mean?) and changed it to -33 to +33
I will give that a shot.
Thanks for the reply
Yep, that's it mate.
Change latency to auto too if u have'nt, use master tempo to fast n disable beatlock (If u enable it) by pressing B on ur keyboard. Let me koe how things shape up.
@Jimmy B
Yes mate kewl to see u here tooLaughing
thanks for the help guys, I have made those changes and will test it out tomorrow, I will let you know the outcome.
Thanks again.
One more questions, Im trying to use the 6+6 button configurator, but i have no idea how to. Do either of you know how I can set the buttons to different effects, preferrably downloaded effects. It ask for values i have no idea what those values are for.
Thanks again.
Have you tried the basic button changes with in VirtualDJ. Try this VDJ config>Remote control>MK2 icon>config, brings up some basic function you can change them buttons for.
Yes, I tried using the basic config but it only has the effects that come with VDJ, im trying to use some that I downloaded from the VDJ site.
Thanks!
Any other ideas?
Page 1 / 2
