pitch problems
pitch controls are somewhat insensitive they tend to jump around, for example when i am beatmixing and trying to match bpms it seems to jump around, if the playing song is 135, i can not always get the other one to match it tends to jump higher or lower. has anyone experienced this problem? any suggestions?
thanks
i went to config - options in the vdj software (is that what you mean?) and changed it to -33 to +33
yep, thats it mate.
change latency to auto too if u havent, use master tempo to fast n disable beatlock (if u enable it) by pressing b on ur keyboard. let me koe how things shape up.
@jimmy b
yes mate kewl to see u here toolaughing
changes latency to auto too if u havent, use master tempo to fast n disable beatlock (if u enable it) by pressing b on ur keyboard. let me know how things shape up.
@jimmy b
yes mate, kewl to see u here toowink
thanks for the help guys, i have made those changes and will test it out tomorrow, i will let you know the outcome.
thanks again.
one more questions, im trying to use the 6+6 button configurator, but i have no idea how to. do either of you know how i can set the buttons to different effects, preferrably downloaded effects. it ask for values i have no idea what those values are for.
thanks again.
have you tried the basic button changes with in virtualdj. try this vdj config>remote control>mk2 icon>config, brings up some basic function you can change them buttons for.
yes, i tried using the basic config but it only has the effects that come with vdj, im trying to use some that i downloaded from the vdj site.
thanks!
any other ideas?
What version of VDJ u using? Is this on mk2 and are u using timescode?
I am using VDJ 5.1 pro with hercules RMX. No timecodes
What is your Pitch range set at? mine is on 33%
@spinnaJ, fancy meet you here mateSmile
I went to config - options in the VDJ software (is that what you mean?) and changed it to -33 to +33
I will give that a shot.
Thanks for the reply
Yep, that's it mate.
Change latency to auto too if u have'nt, use master tempo to fast n disable beatlock (If u enable it) by pressing B on ur keyboard. Let me koe how things shape up.
@Jimmy B
Yes mate kewl to see u here tooLaughing
thanks for the help guys, I have made those changes and will test it out tomorrow, I will let you know the outcome.
Thanks again.
One more questions, Im trying to use the 6+6 button configurator, but i have no idea how to. Do either of you know how I can set the buttons to different effects, preferrably downloaded effects. It ask for values i have no idea what those values are for.
Thanks again.
Have you tried the basic button changes with in VirtualDJ. Try this VDJ config>Remote control>MK2 icon>config, brings up some basic function you can change them buttons for.
Yes, I tried using the basic config but it only has the effects that come with VDJ, im trying to use some that I downloaded from the VDJ site.
Thanks!
Any other ideas?
Page 2 / 2
