please a good soul ...
please a good soul help me, no headphone sound on rmx2 : (
hi, i really really need help here. ive managed to get through a few problems etc and now im having trouble getting the sound out my headphones and the speakers etc. ive tried messing round with the output things but i just cant get it right and ive been trying for days now haha. can some good good soul please help me as im totally lost on what to do. thank you in advance : )
I'm using DJuced if that helps aswell. Please, anyone?
Dear Taylor
Can you tell us first if you are under Windows or MC OS?
I will suppose your are under Windows.
Can you check in the DJUCED settings that DJConsole RMX2 ASIO is selected as Audio Device and Output 1-2 as Master and Output 3-4 as Headphone.
Open the RMX2 CPL and check that you have in the advanced setting Headphone channel assigned to output 3-4 as default.
Keep DJUCED Opened , Then press the headphone button of the corresponding deck you want to heard ( on DJUCED interface or RMX2 console ).
Play a song on that deck, and check that the headphone volume button of the dconsole is not at the minumum.
Hello Taylor,
Enclosed is the most standard audio setting of a DJConsole Rmx2 with Djuced 40 in Windows.
- Audio Device = DJConsole Rmx2 ASIO
- Sampling rate = 96000 Hz
- Outputs
    - Master: Outputs 1&2
    - Headphones = Outputs 3&4
- Inputs
   - Deck A = Inputs 1&2
   - Deck B = Inputs 3&4
Djuced 40 reference manual is online here.
