please help!!!!!!
please help!!!!!!
just upgraded to rmx2 i can be playing a track perfectly, when i load another track the gain on the first track drops dramatically.then after a while nothing no sound output or any thing. please help if possible hopefully i just need to change settings.          many thanks double jay dee
Please provide some information about your computer specification and software configuration. Otherwise, it will be quite difficult to help you.
Hi there been playing with settings & solved the sound issues, plays tracks with no problems.
Only thing now none of the LED's are working now for some reason.
                    Thanks for taking the time to try and help me it is much appreciated.
As mentionned before, if your don't indicate which software (and specific version) your are using, your computer specifications (operating system , version, etc) and what steps you've taken so far, it is hard to potentially say what could be wrong.
