please help head is...
please help head is batterd
right il try to explain this as easy as possible...
i have just bought dj control ep2. and iv downloaded a full version of dj pro. i have bought a usb sound card.
i want to hook my control/vdj up to my pioneer mixer. i read somewere if i config the settings to deck 1: front output / deck2: rear output...they would play out seperate channels on my mixer. and then i can use my external mixer to que and preveiw tracks in headphones....how ever it will not work πŸ™
i will upload some pics to see if they help lol
if u can see the pics you will see my soundcard has front out and rear out....if anybody could give me instructions that would be great....if not il be gutted i cant use my ep2 πŸ™
With your Setup, I think that the best is :
  • Go in VDJ audio setup.
  • In Inputs, select "none".
  • In Outpouts, Select "External Mixer"
  • In Sound Card, Select Your Soundcard.
Plug the Front out of your Soundcard on a channel of your Mixer, and the Rear one on Another Channel.
So you can use your External Mixer to Mix and Cue, the MP3 E2 is here only to Control VDJ Playback.
thank you i will try that and let you know the outcome
hopfully it works
