please help to set ...
please help to set up
is anyone can tell me how to set up audio 8 dj with my virtual dj 5.2.2 ...is it possible ?
hello monkata,
if your version of virtualdj 5.2.2 is virtualdj 5.2.2 pro: yes, you can use your audio 8 dj with virtualdj 5 pro.
if your version of virtualdj 5.2.2 is virtualdj 5.2.2 djc: no, you cannot use your audio 8 dj with the rmx in virtualdj 5 djc, since virtualdj 5 djc use dj console rmx as sound card, and cannot let you activate another sound card.
thanks for the help bro ..know im get it πŸ™‚
Hello Monkata,
If your version of VirtualDJ 5.2.2 is VirtualDJ 5.2.2 Pro: yes, you can use your Audio 8 DJ with VirtualDJ 5 Pro.
If your version of VirtualDJ 5.2.2 is VirtualDJ 5.2.2 DJC: no, you cannot use your Audio 8 DJ with the Rmx in VirtualDJ 5 DJC, since VirtualDJ 5 DJC use DJ Console Rmx as sound card, and cannot let you activate another sound card.
Thanks for the help bro ..know i'm get it πŸ™‚
