plzz help for dj co...
plzz help for dj console
hello guys,
i have a broblem with a dj controler i have the cd but it s for win xp ....and i have now win 7 ..i have installed the latest drivers but i dont have a software ..i m trying to install a software from the cd virtual dj but  it says the controler has not been detected.
please plug the controler and start virtual dj again!
what can i do?laughing
thanks
when installing the drivers did you wait til it said please plug in controller. also ignore anything that pops up unless its the software . try deleteing everything from your computer. restart and and insert cd into drive double click on it . if it does not auto run. install the drivers first. wait til it says please plug in your controller. after that install vdj and then after all of that update to the new drivers.  restart your computer . plug back in your controller n start vdj and should be working fine. ill check back on ya in a few im sitting in a western civ class @ the moment.
hello binakos,
please precise the name of your controller.
which controller is it:
- dj console 1 (mk1),
- dj console mk2,
- dj control mp3,
- dj console rmx,
- dj control steel,
- dj control mp3 e2,
- dj console mk4?
when installing the drivers did you wait til it said please plug in controller. also ignore anything that pops up unless its the software . try deleteing everything from your computer. Restart and and insert cd into drive double click on it . if it does not auto run. install the drivers first. wait til it says please plug in your controller. after that install VDJ and then after all of that update to the new drivers.  restart your computer . plug back in your controller n start vdj and should be working fine. ill check back on ya in a few im sitting in a western civ class @ the moment.
Hello Binakos,
Please precise the name of your controller.
Which controller is it:
- DJ Console 1 (Mk1),
- DJ Console Mk2,
- DJ Control MP3,
- DJ Console Rmx,
- DJ Control Steel,
- DJ Control MP3 e2,
- DJ Console Mk4?
