pre listen problem ...
pre listen problem with the rmx
hello everyone, thanks for passing by before everything.
ill make it quick, i have recently bought an rmx but i cant benefit from the pre listen option, i mention that i have no speakers or external mixers connected to my rmx, its only my pc speakers.
(i use a vdj 7.3 full pro without the rmx skin).
please, im waiting for your reply, thank you hercules mates :d
have a good day πŸ™‚
First, set the audio configuration menu as follow in Virtual DJ
Input: None
Output: Headphone - Master: Ouput 1&2 / Headphone: Output 3&4
Soundcard: Rmx
Once done, apply the procedure described in this document:
  http://ts.hercules.com/faqs/eng/her_eng_00455.pdf
Still not working. :/
Now, I can only listen to headphones connected with the RMX
Depending on your computer's onboard soundcard, the proposed procedure may or may not work.
Your best bet is to get speakers to connect to the Rmx.
What speakers do you recommand?
