1
Posts
2
Users
Reactions
Views
20/12/2014 8:13 pm
hello,
i have just bought a traktor 2 pro licence and have connected it with my dj control air 4780722 and everything works perfectly. however there is a single problem: i cant prelisten with my headphones i connected on the controller. when i try to change it in the settings it is dont even shown in the selections. how can i set up my headphones to traktor?
thank you for answers
21/12/2014 6:23 am
The PDF document included with the MIDI mapping file available from the Technical Support site will give you the configuration to use to use your headphones properly:
http://ts.hercules.com/download/sound/TDJS/current/TP2_DJ_AIR.zip
