problem monitor cue...
problem monitor cue - hercules dj control instinct
i have a problem !!
i have a controller hercules dj control instinct mapped in traktor pro 2
i can not hear deck a or b through the headset separately with the cue monitor, while listening to the master.
i hear bands overlapping songs! but not limited to the selected deck.
in the master plays only one track ... ok ... but the headset hear both tracks !!!
and the output routing is configured as the manual mapping.
** in djuced is functioning normally.
what should i do?
If you look at the Traktor interface, you'll notice underneath Deck B some controls for the headphone output:
- When the MIX knob is in the LEFT position, you will hear the deck for which the CUE SELECT has been activated
- When the MIX knob is in the Right position, you will hear what comes out of Output 1-2, according to the crossfader position.
- If you want to hear a bit of both (when preparing a track), simply put down the middle position.
