and post the address Wetransfer gives you, either here on on the forum Djuced.com so that we analyze the crash.
In the list of programs, select Djuced 40
In the bar on top of the list of programs, click Uninstall
my version is 3.6.10 not the 9
ok i wait your version 🙂
firmware is 1.4.2.30
thank you, WHEN DOES I CAN NOT USE THE JOG AND THE AUDIO FADER WITH SYNCHRONIZATION? ops
it seems that, if I wanted to use the jog to time the tracks do not work much, like vynil, im new with this machine i need practice maybe, but the jog work well with the start and stop touch in the superior part
and with some wheell ....i let you know ...
thanks
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin-top:0cm;
mso-para-margin-right:0cm;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0cm;
line-height:115%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;}
