problem with 4-mx a...
problem with 4-mx audiocard (possibly?)
hi!
my 4-mx has been in the closet for a while now and i just pulled it out today and tried djing with traktor 2.
the problem i have is, that i only get sound from the left side of my speakers / headphones.
i wonder if this is a driver or a soundcard issue. all my settings should be allright and when im using asio or my built in soundcard everything works fine.
i appreciate any help, thank you!
- jeijo
1) Set DJ Console 4-Mx in Asio (in DJ Console 4-Mx control panel) mode prior to running Traktor
2) In Traktor Pro , Audio Setup, chose "Hercules DJ Console 4-Mx ASIO" as Audio Device
- Audio Device: Hercules DJ Console 4-Mx ASIO
3) In Traktor Pro , Output Routing, set
- Output Monitor: L = 3: Output 3
- Output Monitor: R = 4: Output 4
- Output Master: L = 1: Output 1
- Output Master: R = 2: Output 2
4) Please describe your audio connections: where do you connect your speakers and your headphones.
