problem with 4set
problem with 4set
hi !! my half level bass knob has +36% value in traktor n vj ... !! is it some kind of hardware problem ?? can i reset the dj 4set knob values ??
thanks !
What do you mean exactly by +36% and reset the knob value?
Traktor and Virtual DJ Pro indeed allow you to modify the frequency range or the type of EQ used.
The bass knob on A/C deck is at +36% value in traktor n VJ, when on the controller its at half level ...
Then I would recommend testing the knob using the following method:
PC:  http://ts.hercules.com/faqs/eng/her_eng_00420.pdf
MAC: http://ts.hercules.com/faqs/eng/her_eng_00422.pdf
If indeed you see that he knob does not cover the entire range it should, then there is certainly a hardware problem and a replacement would be in order.
It does cover the entire range, but the half level value is +36% ! and sometimes it changes value without being touched !!
