everytime i play a track with my controll, there come cracking sounds. this is really annoying and it just goes away if i reopen djuced. but if comes back after a few secons. please help me
First, be sure you are using the latest drivers and software update
Next, apply the recommandations of the following guide:
PC: http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
MAC: http://ts.hercules.com/faqs/eng/her_eng_00363.pdf
If you're using a laptop, try using it with the power supply plugged in (and not on battery). I recently had audio glitching on a laptop that apparently has a power plan for battery operation that djuced didn't work well with. Plugged the same laptop in, and this problem went away.
