problem with djcont...
problem with djcontrol instinct and macbook pro
hello
i have a problem using djcontrol instinct with my new macbook pro.
i have always used djcontrol instinct with windows and ive never had problems.
now that im using it with my macbook pro it doesnt work.
djuced it doesnt work: it doesnt respond and it doesnt play the tracks on the desk. it seems to seize up.
djcontrol instict doesnt appear in my "utility" when i connect it to the usb port.
what should/could i do?
thank you!
Please precise
- your Mac OS operating system (for example Mac OS 10.9.3),
- your DJControl Instinct drivers (for example package 5.03),
- your Djuced 18 version (for exemple 1.0.90).
I am not sure I see what you you mean in writing DJControl Instinct doesn't appear in your "Utility" when you connect it to the USB port: do you mean that when you go in Application > Utilities > Audio MIDI setup > Window> Show MIDI window you don't see DJControl Instinct in this MIDI window?
If that is your case, can you check if changing the Configuration in the MIDI windows from Default to New configuration, and saving a configuration with the name you with makes DJControl Instinct appear?
