problem with driver...
problem with drivers
when i go to the device manager , drivers of my console rmx are on this icon (!)yellow, where is the problem?
good saw numerous insect solutions. The switches showbox at the moment, you can locate a link for the Showbox best.
The yellow exclamation mark in Windows Device Manager means something is not working properly (which may be hardware, software, driver, firmware).
1) As you meet any technical problem, please complete your profile in clicking on "My Space"> "My Profile"
http://www.herculesdjmixroom.com/en-us/account/informations/
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-pagination:widow-orphan;
font-size:10.0pt;
mso-fareast-language:EN-US;}
- In "Hercules equipment in use", please check your Dj controller,
2) If your PC is in Windows 8.1 or Windows 10 and has USB 3 poetr, can you test on a PC with an older system to see if your Rmx is properly detected?
font-size:10.0pt;
