problem with my new...
problem with my new rmx 2
hi everybody,
i have a question for you: im trying to use my controller at home and after one hour the sound in headphone is bad... seems bad scratched and disconnected in bpm. why? the only solution is to restarted djuced. if this problem start in a disco night??? omgcry
My first suggestion would be to be sure your are using the most recent drivers for your controller, as well as the latest version of DJUCED 40.
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=308&cid=1
Once this is done, the next step is to optimize your computer for DJ usage. It might seems like you are only playing music, but it does actually require a fair amount of ressources from your computer, and if your computer is not configured properly, this could lead into problem such as what your are experiencing. The follow guide will help obtain better performances out of your system:
PC: http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
MAC: http://ts.hercules.com/faqs/eng/her_eng_00363.pdf
Also, if you are using a PC computer, you also might want to configure your ASIO driver correctly, as described in this guide:
http://ts.hercules.com/faqs/eng/her_eng_00447.pdf
Let's see if this helps!
