hi,
when i am moving the vinyl timecode backwards in order to make the backspin i hear no sound....only when i am scratching the vinyl clockwise i can hear the sound...
what is happening ???
can i fix it ??
i am using the virtual dj vinyl timecode....
hello theo
each time you ask a technical question, please start by describing
1 - your configuration
(for example:
- laptop - dell inspiron 17 - cpu: intel core i5 - windows 7 - 4 gb ram
- dj software: virtualdj le tc 6.0.4,
- deejay trim 4&6 + scratch sound card with drivers: 2010_hdjs_2)
2 - your connections
(for example:
- deejay trim connected directly in the laptop (not through a powered usb hub)
- 2 technics sl-1200 mk2 connected to deejay trim input 1-2 and 3-4 set in phono mode, with shure m44-7 cell on both technics turntables
- outputs on mixer korg zero 4, deejay trim outputs 1-2 and 3-4 connected on korg ch 1 and ch 3 inputs, and turntables passthrough (for audio vinyle discs playback) connected on korg ch 2 and ch 4)
3 - your software setting
(for example
- virtualdj time code settings: timecode vinyl, absolute mode
- advanced time code setting: clearsound on, disable antiskip)
Hello Theo
Each time you ask a technical question, please start by describing
(for example:
- Laptop - Dell Inspiron 17 - CPU: Intel Core i5 - Windows 7 - 4 GB RAM
- DJ Software: VirtualDJ LE TC 6.0.4,
- DeeJay TRIM 4&6 + scratch sound card with drivers: 2010_HDJS_2)
(for example:
- DeeJay TRIM connected directly in the Laptop (not through a powered USB hub)
- 2 Technics SL-1200 Mk2 connected to DeeJay TRIM input 1-2 and 3-4 set in phono mode, with Shure M44-7 cell on both Technics turntables
- Outputs on mixer Korg Zero 4, DeeJay TRIM outputs 1-2 and 3-4 connected on Korg CH 1 and Ch 3 inputs, and turntables passthrough (for audio vinyle discs playback) connected on Korg CH 2 and CH 4)
(for example
- VirtualDJ Time code settings: Timecode Vinyl, Absolute mode
- Advanced time code setting: Clearsound on, disable antiskip)
