problem with virtua...
problem with virtual dj 6 et dj control mp3 e2
hi all! im new in this forum & i have bought the new dj control mp3 e2 but i have a problem with virtual dj 6. when i open the software, the dj control mp3 e2 doesnt works (it works only with virtual dj djc edition, software included in the packing).
have i to configure key by key in the configuration menu or is there any way to make it works without this "heavy job"???
best regards, and thanks in advance from spain
be sure that your are using the latest update of virtual dj (v6.02) , which fully supports the mp3 e2.
hello everybody!
i got a problem with my new dj control mp3 e2 an virtual dj6.
when i try to use the e2 i got the message "problem with "hercules djconsole mp3 e2 mapping.xml" "
when i open the xml-file (to be found in "userdocumentsvirtualdjmappers") the file is empty, not like all the other files.
i reinstalled it, but it did not fix my problem.
could anybody upload the file for me or send it to me by mail?
if someone would declare to do it, i would send you my e-mail adress by pm.
i hope someone can help me, so i really can start djying =)
greetz, tomtom
hello tomtom,
please detail which version of virtualdj 6 you use: is it virtualdj 6.0.2 pro or another version?
its the demo version, at the moment, because i wanted to try the connection between the e2 and virtual dj 6 before ill buy it. it seems to be version 6.0 and when i click on update, there is a message "no newer version available"
i hope for help!
tomtom
hello tomtom,
virtualdj 6.0 pro doesnt support of dj control mp3 e2, the first build of virtualdj pro integrating dj control mp3 e2 support is virtualdj 6.0.1 pro.
sorry for reopening this thread but my problem isnt fixed at all. i got win7 now but again i cant use my e2 without problems. i started mapping myself but im not completely happy with it. so here again my question:
could anyone upload the mapping file for the "hercules dj control mp3 e2" for me or send it to me per mail?
the file can be found in "c:users\%username%documentsvirtualdjmappers"  and should be named like
i would be very happy if someone could upload it or send it me per mail. if you want my e-mail adress, just ask in this thread and ill post it that my knight in shining armour can send me the file, so i can start my djing career entire. πŸ˜‰
thanks for everybody who would help!
tomtom
hello tomtom,
to be able to exchange emails, it is necessary you accept the invitation i have sent you on this forum. you can go to my space > friends, and accept he invitation, otherwhisei cannot send you any email.
ok, thanks for wanting to help!
i accepted your invitation!
tomtom
tomtom
dear,tom tom
im having the same problem like you and  is that e2 work with mapper(xml) file .
if is working well, pls share your e2 mapper to me and i will appreciate and many thanks to you and maxdjack .
thanks,
zaw
hello tomtom,
dear maxdjack,
im having the same problem like tom tom and i would like to get e2 mapper(xml) from you.
i appreciate your friendly help.
many thanks,
zaw
hey maxdjack,
aparently ive got the same problem and i would like to get e2 mapper(xml) from you, too.
i also appreciate your friendly help. ^^
lots of thanks,
j-tester
hello j-tester,
what is your version de virtualdj?
