problema con dj con...
problema con dj control air e djuced18
ciao a tutti ho un problema con il mio controller hercules dj control air e djuced 18°.
a volte quando suono, dopo circa unora o poco più, capita che il programma si blocca qualche istante e poi manda le tracce al massimo dei bpm (scorrono velocissime) e non ho modo di recuperare in alcun modo la situazione se non chiudendo e riaprendo il programma.
come posso risolvere questo problema?
grazie!
eng:
hi everyone i have a problem with my controller hercules dj control air and djuced 18 °.
sometimes when im playing music on it, after about an hour or so, happens that the program freezes for a few moments and then sends the tracks to the maximum of bpm (fast running) and i have no way of recovering the situation in any way if not closing and i reopen the program.
how can i solve this problem?
thank you!
1) As you meet any technical problem, please fill your profile in clicking on "My Space"> "My Profile"
- In "Hercules equipment in use", please check your Dj controller, DJControl Air,
- In "Software in use", check your DJ software, Djuced,
- In "Describe your equipment": describe your computer brand and model, CPU, quantity of RAM, version of Windows or Mac OS (for example Windows 10 Family, release 1607, 64-bit), version of DJConsole Series driver package (as 2016_HDJS_3), version of DJ software (for example Djuced 18
1.0.102).
2)  Please follow the optimization guidelines for Windows, here:
https://support.hercules.com/it/kb/1001-it/
If you still get this issue which you have followed Windows optimization guidelines, can you check if placing a USB hub powered by a power adapter between your computer USB port and your DJ Control Air solves the issue?
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-pagination:widow-orphan;
font-size:10.0pt;
mso-fareast-language:EN-US;}
