problems when loadi...
problems when loading tracks
hello there,
i am a mac user and i recently got a dj control air. ive been playing around with it and i love it. however, i encountered a problem when loading songs. at first when playing a song on one deck and then loading another song on the other deck it works like it should. but at around the 15-20 minute mark of my mix when i try to load a track on a deck whilst the other deck is playing, the track that is playing begins lag/jump/chop up. is there anyway i can fix this so that i no longer have this issue?
thanks
First be sure to install the latest drivers (v4.47) and DJUCED version (v1.0.64) if this is not already the case:
www.djuced.com/download
Next, apply the advices of the following guide to optimmize the performance of your computer:
http://ts.hercules.com/faqs/eng/her_eng_00363.pdf
thanks! I'll give that a try.
