problems with impul...
problems with impulse 500 crossfader
is there anyone here that can help me sort out my crossfader....the crossfader curve dosnt do what its supposed to
You may expect help if you describe your technical problem.
Tech forums help if you follow forum rules, so you should explain
- your issue with technical words,
- your computer settings as in the posting rules,
otherwise you seem unable to read a tech answer, perform tech operations and report results.
Tech forums are bad if you throw a tantrum as in the double post: tech forums need only tech posts. If a post looks messy, no one think tou will read any answers, so no one will answer.
What's your problem
- controller : crossfader curve switch Slow=Left / Fast=Middle / Disable=Right does not work?
- software:
Serato Pro > Settings > Mixer > Crossfader > does not let you set the Slow / Fast rotary? If yes, what do you want to set?
- or something else?
Have you another Serato DJ controller?
