problems with point...
problems with point cue and loops rmx2 + vdj pro
hi everybody,
sometimes when im playing with point cues or loops something very embarassing happen. its like what im doing on deck a, the rmx (or vdj pro) reproduces it on deck b what is a major problem as you can imagine. for example: i hit cue 1 pad on deck a and that launch cue 1 on deck b at the same time...
did anyone had the same problem? that does not happen very often but damn... i dont want that during a set in a club... and i have one on tuesday :/
heeeeeelp
ps: i did not change the basic mapping.
Have you tried reverting the mapping to the factory setting (far left icon at the bottom of the MAPPER menu)?
Damn yes I tried... I'm mixing tonight. I will just pray, but that's weird that nobody else have the same problem...
What is your version of VDJ Pro (is it 7.3) and your computer configuration (Mac or PC, Operating system)?
Hi man,
It's actually the LE 7.0.5b (that comes with the RMX2 on the CD) upgraded to Pro (demo version for now). All new drivers installed, no other versions of VDJ installed on this computer. And that's a PC (windows 7).
Thanks to help
I have never seen or heard of this issue, but I have not used this VDJ Pro demo version.
Can you confirm if you
1 - had no other version of VirtualDJ installed on this computer prior to installing VirtualDJ 7.0.5 LE version?
2 - have no installed an VirtualDJ Pro plugin before?
3 - see no contents in the folder C:\Users\YourName\Documents\VirtualDJ\Mappers?
Hello Maxdjack
1 - No other version of VDJ installed before, no crack, no downloaded version or something...
2 - No plugins
3 - Now there is a file as I just changed the effects assignations, but I had the same problem with the factory settings.
The only solution that I found for now is to not assign same points cue on two decks (I assign cue pads 1 and 2 for deck A, and 3/4 for deck B) ... Cause that happened again when I was mixing on last tuesday: hited cue 1 on a deck, launch cue 1 on the other deck...
I'm thinking about going back to the LE version without pro features but that pissed me off. Thanks to try to help bro...
I don't know if this will help, but if you put the same track on both decks, in VJ Pro 7 & RMX2, it will automatically cue to the same points. I set up the CUE for nearly all my tracks and test before recording or playing live.
Is the cue mapper set to: CUE_PAD 1 = hot_cue1, etc and is your CUE = var 'shift' ? stop : cue_stop
