question bout conso...
question bout console, sound card.
hi! im new to this and ive got a question. is it true that if youve got dj console with sound card, then i can plug-in my digital piano? (yamaha ydp-140) by midi input? i dont know how to describe it. i want to use this piano as synthesiser on programs such as: reason, fruity loops, cubase.
im a total beginner and i dont know how to start. all i have is this piano, but i want to buy this:   http://www.hercules.com/us/dj-music/bdd/p/125/dj-console-mk4/   but only if i can plug-in this piano to use it as synthesiser.
please help me.
in order to connect you keyboard to you computer, you will need an interface that has midi din-5 in/out connectors, such as this one :
http://www.yamaha.ca/content/computermusic/products/midiinterfaces/ux16/keyfeatures.jsp
the dj console mk4, is , as your keyboard, a midi controller that connects directly to the computer via usb, but does not have the appropriate connectors (din 5) to connect your keyboard to it.
In order to connect you keyboard to you computer, you will need an interface that has MIDI Din-5 In/Out connectors, such as this one :
http://www.yamaha.ca/content/computermusic/products/midiinterfaces/UX16/keyfeatures.jsp
The DJ Console Mk4, is , as your keyboard, a MIDI controller that connects directly to the computer via USB, but does not have the appropriate connectors (Din 5) to connect your keyboard to it.
