re-mapping hercules...
re-mapping hercules dj control air knobs
hello, i am currently using a hercules dj control air (not plus) on windows 10 with the djuced software. i was wondering if it was possible to remap my treble knob to an lp/hp filter, which would suit my interests much more. i saw other posts (like this one) where this was done. any help is greatly appreciated!
Hello Spongus,
Welcome to the forum.
I will look at it at the end of the week (I first need to get a DJControl Air to make sure the mapping works).
Thanks so much! I really appreciate it.
Hello Spongus,
Please download here the mapping "DJControl Air Filter.djm"".
(WeTransfer keeps files online for 1 week, so download the file within 1 week).
Once you have downloaded the file "DJ Control Air Filter.djm",
0) close Djuced app if it was running
1) connect your DJControl Air unit to the PC/Mac computer
2) go in
- Explorer if you use a PC,
- or macOS Finder if you use a mac.
3) click on DJ Control Air Filter.djm file (in Windows Explorer or macOS Finder),
4) it will call Djuced.
5) In Djuced, go in Settings > Mapping, and load from the list "DJ Control Air Filter",
6) Your DJ Control Air will control Djuced Filter function on its 2 Treble knobs.
and let me know if you meet a technical issue.
Worked perfectly, thanks so much! Have a good weekend!
Hello Spongus,
You are welcome, thanks for your feedback.
