recording issue
hi
i have recorded my mix and after i wanted to listing to it and there no mix playing
i can see the created date and the name but nothing is playing
pic attached
thank you
im using inpulse 200 via win 10.
Sorry, I cannot see you picture.
Have you saved your mix in uncompressed format?
HI
i saved the mix in uncompressed fromat
how can i upload an visibale pic that you can see ?
thank you
To upload a visible picture,
1) upload the pix on a picture image hosting service as (but not limited to): Postimages.org, imgur, zupimages, Casimages, Imgbb
2) Copy the link to the image on the hosting website, click on Herculesdjmixroom  insert image button and paste the image link.
Can you check if your wav recorded mix size seems normally big (15 MB/ minute) or is small?
How big is the recorded file?
For a 10 seconds file, it should be around 2.5 MB.
0:18 sec
18:00 min
03:00 min
i tried 3 times
You can right click on your file and choose "Files Operations => Reveal in Explorer/Finder".
It will open the Explorer of your computer and you will be able to see the "Wav" audio file.
(By default in your Userfolder/Documents/DJUCED/Records/Mix)
i did that i can see the wave file but when im playing it there is no sound and the track is running
On your screenshot by the date there are some strange characters. Do you happen to have such in your username as well? If yes, can you set the record folder in settings to one which has latin characters only (like: C:\Mix) and try that way?
so i now can record but now i can hear only one of the deck in the recording file (only deck 1)
no recording from deck 2
im recording when the headphons is plug in no output speakers
If you use only headphones, be aware that Djuced records only what you hear when the Master button is on. Are you sure that the crossfader, the gain knob and the volume fader for deck 2 are in the right position?
Yes evrething is in place
Do you have the right audio settings? Mine goes like this:
ITS LOOK LIKE IT
Apparently not. You have chosen the WASAPI driver while ASIO is recommended (and that's what you can see on my settings screenshot).
Page 1 / 2
