recording with my d...
recording with my dj control air
hey guys,
i wanted to record something with my dj control air on djuced, but when i listen to the file, i cant hear anything only some cracks...
i dont know why it doesnt work and i hope someone can help me, thanks
First of all make sure that you are using the device with the latest software. The driver can be found here:
The DJuced software can be found here:
Reinstall the software and see if the issue persists. If it does tell us the software and hardware config of your computer and also what extension the sound files that your are usign are.
Hey guys,
i have the same problem:
Driver -> 2012.HDJS.5
DJuced -> 1.0.64 (latest one)
OS: Windows 8
File used: *.mp3
I've also tried to reinstall DJuced but the problem is always the same.
after installing DJuced 40° and reinstalling again 18° recording works πŸ˜‰
Thanks in advance ... πŸ˜‰
