rmx 2 and traktor p...
rmx 2 and traktor pro 2
i am a newbie and wanna ask if i could use traktor pro 2 software for rmx 2 instead of djuced and vdj? and if its possible to use traktor, is it better compare to virtual dj?
Simply head over to the Support site where you'll find a MIDI mapping for the Rmx2, along with a document explaining how to configure the audio section and mapping definition:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=308&cid=10
Every software , although similar, each have their own particular way of working which may or may not suite your needs. Your own taste will deceide if it is better.
thanks dude....
