rmx and traktor 3 p...
rmx and traktor 3 problem
hi all!
i just received my hercules rmx the other day, it works fine with the vdj, but ive been using traktor 3 before and i would like to keep using it.
ive been having problems with the sound, when i use hercules soundcard i have this high pitched and cracking sound, and it comes from the headphones and speakers.
when i use my laptops soundcard, it works normaly, but the headphones dont work with the speakers, so sound comming only from the speakers
has anybody any advise? when i try to change the audio output there is only 2 possibilities my left speaker and my right speaker, not 4 options like ive read from other forums...
i would appreciate any help! thanks!!!
cheers!
the following file from the hercules support site contains a guide explaining how to configure the rmx soundcard with traktor 3.
ftp://ftp.hercules.com/sound/tdjs/current/t3_dj_rmx.zip
it also includes a tks file to use the controller part of the rmx.
thanks man! i have to admit that i had that same file, but kind a skipped that part and went straight to the hotkey section... well it works now.. and loving it!! good work and thanks for the quick reply!!!
best regards from finland!!!
sneaky
The following file from the Hercules support site contains a guide explaining how to configure the Rmx soundcard with Traktor 3.
ftp://ftp.hercules.com/sound/TDJS/current/T3_DJ_Rmx.zip
It also includes a TKS file to use the controller part of the Rmx.
Thanks man! I have to admit that i had that same file, but kind a skipped that part and went straight to the hotkey section... well it works now.. and loving it!! good work and thanks for the quick reply!!!
Best regards from Finland!!!
Sneaky
