i have been using rmx with pro 2.5 and have just purchased traktor kontrol s4 which came with pro 2.6
i have uninstalled both previous traktor and hercules files . the s4 is working fine with pro 2.6, i have installed latest driver from hercules site and pro2 map. the rmx works fine with the vdj ssoftware. i cannot get anything at all from rmx with traktor 2.6 i have gone through importing map and followed the usual procedures, i notice when the configuration options are shown when importing map , that only 2 of the 4 items show to tick are not ticked this includes the midi controller tic box. which is in ticked and greyed out so unable to tick ?
i have tried re downloading map and re importing several times, but each time there is no responds from any controls on rmx
i am using macbook pro with latest version of lion os
can anyone help please
Can you check if your Rmx is still on MIDI channel 1?
Hi
yes all settings are as they show on PDF for installation I downloaded
Can you confirm you use the preset for Traktor Pro / Duo 2 here?
On my side, everything seems to work.
I unzip the file.
I open Traktor Pro 2.6.3
In Files > Controller Manager, I click on Import.
I import the TSI file DJ_Rmx_TP2_v212.tsi
Then I confirm the categories in which Traktor Pro 2 proposese to import the file
Then I set Rmx as MIDI device for In port
and for Out port
and I make sure Rmx ASIO is the sound card the Audio setup, and everything is OK.
I cannot control the remix decks, but I can control the standard decks.
