rmx monitor mix pro...
rmx monitor mix problem
i have traktor 1.11.001 and hercules rmx 1.1.29.6 and osx 10.5.6
when the cue select on deck b is on and i turn the monitor mix it dosen t mix with the song in deck a
in the other way seems to work
and when i move the same mix knob to 100% it kill de song in deck a instead of mix the two songs together.
another problem is that when i push the sync button it sets 128 bpm instead of equals the bpm on the other track
has anyone know of an adjustment or something?
thanks!
are you using the mid profile provided by hercules on the tech support site ?
if so, in this profile , the monitor knob of the rmx is linked to the monitor mix function of traktor, which works as follow:
- at 0% (or cue position on the console), you should only hear the deck which has the cue select enabled.
- at 50%, you should get an equal amount of both the cue signal and the main output mix.
however, depending on the volume of both decks, its possible that you might notice a difference in levels, giving you the impression that you only hear one deck.
-  at 100% ( or mix position on the console) you should hear only the main output mix, according to the cross fader position.
to verify that it works correctly, you can use the mix knob in traktor with you mouse. the behaviour should be the same.
Are you using the MID profile provided by Hercules on the tech Support site ?
If so, in this profile , the MONITOR knob of the Rmx is linked to the MONITOR MIX function of Traktor, which works as follow:
- At 0% (or CUE position on the console), you should only hear the deck which has the CUE select enabled.
- At 50%, you should get an equal amount of both the Cue signal and the Main output mix.
However, depending on the volume of both decks, it's possible that you might notice a difference in levels, giving you the impression that you only hear one deck.
-  At 100% ( or MIX position on the console) you should hear only the main output mix, according to the cross fader position.
To verify that it works correctly, you can use the MIX knob in Traktor with you mouse. The behaviour should be the same.
