hi,
i recently started having this problem:
my input channels 1-2 are line 0 db, i always use my rmx2 this way, but recently ive been having problems after rebooting the pc, this config gets messed up. i have to put my audio device (synth) really loud to get any sound, and it gets distorted.
when i see the "djconsole rmx 2" interface (opening it from the tray agent) it shows line 0 db, but it is not processing it as a line 0 db signal.
the way i fix it: i select +6 db, and i select 0 db back; so basically i am not changing anything, i start with -supposedly- 0 db and finish with 0 db, but after i do this it starts working. i dont need to do anything else, just change the selection to something else and put it back to 0 db.
has anybody else seen this? does anybody know a fix?
thanks!
Do you notice any other settings in the control panel that do not seem to apply properly ?
Which version of Windows are you using ?
You have the latest driver package installed (2015_HDJS_6)?
That's the only thing that does not seem to work OK.
I use Windows 10 Home.
Driver Pkg 6 HDJS 2015 (Firmware 1.34 -19, Driver 4.4.8.0)
