rmx2 / traktor pro ...
rmx2 / traktor pro mappings not working
he guys,
im fairly new on this forum. have a rmx2 since last year.
ive managed to download the original and traktor bible mappings and that worked fine.
however, my laptop crashed, reinstalled all software and drivers, downloaded the new mappings but...
somehow none of the mappings work correctly ??
i miss functions like play/pause, kill switch, sync and all those features.
some do work.
has there been some software / firmware change which screws the mappings ?
or can i download a confirmed working mapping ?
thanks all !
cheers
sebas
ok, this gets odd...after deleting all mappings and importing the default, things start to work.
The imported the `franky´s version, mappings screwed again.
then deleted all mappings and imported only ´franky´s version... things work ?
What happend ? Is is common to happen ?
The most likely issue if that the MIDI channel of the Rmx2 was changed: make sure the MIDI channel is set on 1.
Run DJConsole Rmx2 control panel and set MIDI channel on 1.
If you do not know where the control panel is, then please complete your profile in clicking on "My Space"> "My Profile"
http://www.herculesdjmixroom.com/en-us/account/informations/
- In "Hercules equipment in use", please check your Dj controller, DJConsole Rmx2
- In "Describe your equipment": describe your computer brand and model, CPU, quantity of RAM, version of Windows or Mac OS, version of DJConsole Series driver package, version of DJ software,
so that I can write the folder path where the control panel is located.
Another possibility is that there are conflicts between the mapping, if you have loaded several mappings. You should load only 1 mapping for 1 controller.
