scratch with hercul...
scratch with hercules universal dj
is there any setting to be done while scratching with hercules universal dj with djuced40 ?
i activate scratch mode through universsal controller but scratch sounds are not as per what scratch sound to be ! would anyone help me to configure in djuced40 if anything to be changed in setting section.
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-pagination:widow-orphan;
font-size:10.0pt;
mso-fareast-language:EN-US;}
font-size:10.0pt;
Please precise what you expect as scratch sound.
The most standard scratch sound are sound produced in scratching on human voice, speaking or shouting.
Scratchers often use a scratch track, a sound track made with some scratch sounds, so that their scratch sounds exactly as they expect.
Djuced 40 includes a scratch track, it is the file DJUCED_Scratch_Tools.mp3 located in the folder C:\Program Files\DJUCED 40\Demo if you are in Windows.
Please fill your profile in clicking on"My Space"> "My Profile"
- In "Hercules equipment in use", please check Universal DJ in the list,
- In "Software in use", check Djuced,
- In "Describe your equipment": describe your computer brand and model, CPU, quantity of RAM, version of Windows or Mac OS, version of DJConsole Series driver package, version of Djuced 40.
