serato scratch live...
serato scratch live + hercules control air
hi everyone!
i was searching for mapping to work with control air and serato scratch live. couldnt find it... maybe you know where can i get it?
This tutorial will teach you how to create your own mapping:
http://serato.com/scratchlive/support/1929/midi-in-scratch-live-101
But when I connect my controler, serato can't recognise it and i can't click on "MIDI" button in the program...
You've first verify that the DJ AIR is installed correctly and works as a MIDI controller ?
PC:
http://ts.hercules.com/faqs/eng/her_eng_00433.pdf
http://ts.hercules.com/faqs/eng/her_eng_00435.pdf
MAC:
http://ts.hercules.com/faqs/eng/her_eng_00434.pdf
http://ts.hercules.com/faqs/eng/her_eng_00436.pdf
If this is the case, then it should normally be possible to configure it in Serato.
Was your Serato mixer or interface connected when you tried to map it ?
You are using the latest version of Serato (v2.5)?
So you need to have a serato controller/mixer in order to use it to match say my rmx2?
Indeed, since Serato is designed with scratching in mind, it requires at least a compatible audio interface, mixers (to connect turntables) or CDJs to run.
Once you have that basic setup, you can add any MIDI controllers to enhance your control possibilities of the software.
