can someone provide step by step instructions to set up the rmx2 with turntables (1210s) and virtual dj pro (mac), epecially configuring the timecoded vinyl (serato). thanks
Things are not as complicated as they seem if you take them one step at a time.
1) Start by connecting your turntables to Input 1-2 and Input 3-4.
Don't forget to also connect the Ground wires to the screws on the back, as well as setting both switches to Phono.
2) Launch Virtual DJ and set the following configuration under Sound Setup:
Input: Timescodes
Output: Headphone > Master : Chan 1&2 / Headphone: Chan 3&4
Soundcard: 4-Out card > DJConsole Rmx2
3) Follow the instructions of the Timecode configuration guide to calibrate your system
http://www.virtualdj.com/wiki/TimeCode%20Config.html
