slow fading problem
slow fading problem
hi ive just bought the hercules dj control mp3 and am mixing bouncy/scouce house tunes. part of my style of mixing is with the left and right faders dropping in certain beats and words as and when nessesery. when doing this im finding that the faders are too slow to imput the beat required. would anyone know if it has somthing to do with the settings on vdj?
a quick responce would be appriciated.
peace
djnunu
keep in mind that you are using a controller and not an audio mixer , so you have to expect differences in the behavior:
- on an audio mixer, moving the fader affect the amount of audio signal being sent out. this is done directly on the audio signal.
- on a controller, moving the fader tells the software that you would like to the audio signal to be modified. delays may obviously occur depending on many factors (the speed of your computer, what other operations are happening at the same time, traffic on the usb controller, etc)
 i would recommand reading the following guide which shows many changes that can be applied to your computer to improve performances:
note: the support site seems to have a problem right now, but try later to access the document.
Keep in mind that you are using a controller and not an audio mixer , so you have to expect differences in the behavior:
- On an audio mixer, moving the fader affect the amount of audio signal being sent out. This is done directly on the audio signal.
- On a controller, moving the fader tells the software that you would like to the audio signal to be modified. Delays may obviously occur depending on many factors (the speed of your computer, what other operations are happening at the same time, traffic on the USB controller, etc)
 I would recommand reading the following guide which shows many changes that can be applied to your computer to improve performances:
NOTE: the support site seems to have a problem right now, but try later to access the document.
