sofware compatibili...
sofware compatibility of dj console 4-mx and djconsole rmx 2 premium tr
hi,
is native instruments traktor pro 2.10 compatible with dj console 4-mx and djconsole rmx 2 premium tr???
all the mappings, i mean. does it have official mapping for dj console 4-mx and djconsole rmx 2 premium tr???
your help is appreciate.
thanks.
Hello Evalion,
Yes, there are official mapping files on ts.hercules.com:
- For DJ Console 4-Mx here (The file TP2_DJ_4Mx.zip must be unzipped to get the 2 tsi preset files - for Windows and Mac -, and the pdf files explaining the settings)
- For DJConsole Rmx2, installing Traktor Pro 2.10 installs the TSI preset file "02 - Controller - Hercules - DJ Rmx2.tsi"  in the folder C:\Users\YourName\Documents\Native Instruments\Traktor 2.10.0\Settings\Default Settings\Controller\Hercules or its equivalent for Mac OS.
DJConsole Rmx2 Premium TR uses the same TSI file as the regular DJConsole Rmx2 as it is a DJConsole Rmx2, with Traktor LE included instead of VirtualDJ LE, and with a black skin, a pack of additional caps (yellow caps to be visible on the black skin) and a kit of audio cables.
Hi Maxdjack,
Thank you so much for the info!!!
+1 Like Cool
