sound card problem?...
sound card problem? (dj air control)
hi,
recently, ive encountered some weird bugs and i was wondering how i can solve this it really gets annoying.
when im mixing with the controller (i use traktor 2.0), it can suddenly freeze for half a second and the speed of the song just goes 3 times faster. i thought it was a soundcard problem so i dropped a bit the controller ms to 17ms but it does still happen. what can cause this bug ? im really desperate ...
Have you ever tried to optimize your your computer as explained in the following document ?
Did this, made a partition on my harddrive and it seems better but, now my crossfader just dissapeared in my software ? Traktor detects the movement of my control on my controller but there's no bar movement on the software, i restarted it, tryed to desactivate crossfader and reactive it but nothing... Any idea on this?
Solved the crossfader problem
For the first problem, it just happened again 2minutes ago, i really don't know what to do now to be honest... i have a party plan on next sunday i have to get this thing fix
Looking back at your original post, you said you are using Traktor 2.0.
Did you mean Traktor 2 or are you refering to the specific version (for example Traktor 2, v2.6.1, which is the most recent version available)?
If you are still using Traktor 2 v2.0, I would highly recommand updating to the latest version, has there has been many improvements since.
I would also recommand analysing your computer's performances as described in the section " Third-party Analyzing Tools":
http://www.native-instruments.com/knowledge/questions/847/Windows+7+Tuning+Tips+for+Audio+Processing
